danieru
Greetings!
I would like to move an electric radiator to another wall. The radiator at it's current location is properly grounded, but the wiring on the target wall, unfortunately does not have a ground wire.
So some questions are:
How important is it to wire electric radiators with ground?
Is a GFI outlet a viable alternative if running a ground wire into the target wall isn't feasible?
Some info that may be relevant: I live in Sweden, and the radiator is rated for 230/400V up to 2000W, though I've looked at the wiring box for the radiator at it's current location and it's wired for 230V right now. My house was built in the 70s, and many of the wall outlets are wired without ground. I do understand the general purpose of having applicances properly grounded, but am less clear on in which cases it's particularly important, such as this.
Any suggestions/info are welcome.
