Discuss Is an rcd in a box a consumer unit? in the UK Electrical Forum area at ElectriciansForums.net
Hi,
The supply to my MILs shed doesn't have rcd protection. The board supplying the shed is an old one and the mcbs can't be changed to rcbos
is it notifiable to take the existing shed supply cable that's coming out of the CU and redirect it through an rcd or rcbo in a single module box?
i wouldn't be replacing a CU and if adding an fcu isn't adding a new circuit then surely adding a single smaller breaker downstream of an existing one isnt creating a new circuit either? the original fuse is still protecting the original wiring at the origin of the circuit. all i've done is added more protection to the cable before it goes outside.
So i was just wondering if what i suggested is notifiable? and can the module box be plastic or does it have to be 18th edition metal etc?
I mean it wouldn't be notifiable if i was adding a double pole isolator in a box, so i'm hoping a single breaker in a box isn't a consumer unit either.
Thank you for reading
just fit a stand alone RCD in an enclosure. the small "garage board" would do with just a RCD in it. add a MCB if required. not notifiable under part P as it's just an alteration to an existing circuit.
Fitting a Stand alone isolator / rcd is NOT a notifiable job
Replacing an MCB / Rcbo is NOT a notifiable job
Reply to Is an rcd in a box a consumer unit? in the UK Electrical Forum area at ElectriciansForums.net
Ok, most new Consumer unit seem to come with a 63A RCCB and two MCBs. Most house consumer units now will also have RCD of some type be it a dual...
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
Hi everyone, I wondered if anyone could help me with something that has been niggling me please?! When a Solar PV feed in circuit is installed...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
