Discuss Is connector block allowed inside a fuse board? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, wondering if someone can clarify this or refer me to a regulation regarding using connector block inside a Consumer Unit, I have some cables that are being moved the the RCD section of the CU but are too short and there is no practical way to get more length without making a mess. I’ve heard conflicting opinions regarding this but i couldnt seem to find a reg saying otherwise.
Answers appreciated :)
any suitable connection is fine within the confines of a consumer unit.
it must be rated for the voltage and current that could pass through it.
however, as above, I would be fitting a wago connector or a row of din rail connectors if there were more than 1 or 2
No issue i can see, its just another maintenance joint in the CU, although Wago are getting smaller. they are ideal when you want it neat, I have tried crimps on T&E but actually prefer connector blocks.
best solution i have found is ideal in line push-in connectors (for 1.0mm to 2.5mm) as cable entries are in line, not side by side as with wagos. crimp connectors are also acceptable.
Have used those a few times recently and really like em for saving space...
Reply to Is connector block allowed inside a fuse board? in the UK Electrical Forum area at ElectriciansForums.net
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Hi, I’d appreciate views on the fuse board. https://ibb.co/xj0BtZt It’s been completely rewired and I’m unhappy with the quality. I’ve...
14K
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Hi all, looking for some advice with regards to extending cables for a consumer unit change. The old board is a mess inside with cables being cut...
8K
