Discuss Is earthing required in this context? in the UK Electrical Forum area at ElectriciansForums.net
Hoping someone here can enlighten me - I'm trying to work out if this is at all correct, or just utter tosh. The context here is a model train set (powered by using a "wall wart" style plug to provide 12V to the rails for powering model trains.)
If you can touch any part of the circuit (such as the rails) then HSE & PAT rules say the system must be earthed. Those plugs have plastic earth pins. They are not earthed. It may only be low voltage but 'double-insulated' doesn't count where you can touch metal.
I'm having a hard time believing this is correct as pretty much all such power supplies (designed for powering model train sets, both new and old) seem to be double insulated with no earth pin. But I'm certainly no reg expert.
I think you need to ask them to show you the exact part of the 'PAT' regulations that state this. I suspect they have misinterpreted them.
Ask them to explain a double insulated (ie. Class I I) drill which has a metal chuck
Whoever came up with that nonsense is dangerously misinformed. Double-insulation specifically refers to insulation sufficient to render exposed metal parts safe to touch without earthing, as no single fault can render them live.
Where did that information come from out of interest?
A Facebook thread on a model train group. (Any kind of electrical discussion on there is always painful, but sometimes I like to check I'm not going completely mad before calling BS.)
In fairness, and to complicate things further, the product that prompted the discussion is somewhat dubious IMHO (12v DC Split Power Supply Kit. (inc PCB and 2x Universal Wall Plugs) - https://www.dccconcepts.com/product/12v-dc-split-power-supply-kit-inc-pcb-and-2x-world-usable-wall-plug-power-supplies/) - but not for the reasons stated.
Reply to Is earthing required in this context? in the UK Electrical Forum area at ElectriciansForums.net
Hi, I've bought a "yagusmart" smart switch from Amazon and it has no earth terminal. Although there are no metal facing parts I would think the...
Hi all, For clarity, I'm not a qualified electrician, but have a reasonable amount of experience as I've done plenty of wiring (signed off by a...
Hi all, Hoping someone can shed some light on this, i have purchased a surge protector and it will not fit the power cables i plan on using. I...
A customer has asked me to install a generator to supply her house for when they have a power cut. I have already said this is beyond my...
6K
Good afternoon I hope everyone is keeping well. I have purchased a stainless steel recirculation cooker hood which has the double insulated...
