Discuss is it a requirement to have a isolator between the supply meter and the fuse board in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Elo,
Can anyone help me with some advice please. If an installation has no isolator between the supply meter is they a requirement to upgrade it when doing a PIR, if so what code would it be marked down on the PIR as in both domestic or commercial installations?
Re: is it a requirement to have a isolator between the supply meter and the fuse boar
No requirement.
Also it's no longer a PIR
Between the supply meter and .......?
No requirement.
always assuming that the installation has a single point of isolation, though.
It would depend on the distance between the meter and the distribution board and how the tails are installed.
A single point of Isolatation, or a durable warning detailing the position of other points of isolation should be provided for each installation.
It should also be noted, that for many years premises with a separate CU for storage heaters have been considered as having two installations.
Not really a problem, if both the storage heaters CU and the Power and lighting CU are near each other.
Reply to is it a requirement to have a isolator between the supply meter and the fuse board in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
