I would never alter the design from ideal simply because of cable length. I equally have had problems with through crimps on solids, end up giving them a huge tug to feel confident. I have no issue using a connector block, where, appropriate, once you have a look at the neutral bar, earth bar and all the connections on the breakers there really is no difference between a connector block and these other connections inside the CU. Its a maintenance joint just like all the other ones in there that should be checked for tightness in the appropriate period between tests.
