Discuss is it okay to extend shower cable or should i do new run. in the UK Electrical Forum area at ElectriciansForums.net
Hi guys,
im installing a electric shower and at same time removing an immersion heater.
I was going to use the cable for the immersion heater as its big enough and on its on circuit.
Only thing is its about 2 meters short of were the shower is to be located. It would save an arful lot of messing if i could use this cable. so im asking is it okay to extend this cable (as per regs) with the likes on a junction box in the loft?
thanks
what's the shower rating, and what cable is on the immersion?
Strange question, is it alright to extend a cable? It can be, depends on how you extend it and what with. See above, shower rating?, existing cable size? etc etc.....
hope it's not 10.5kW shower going on 2.5mm. bonus of a heated towel drier.
2.5mm is the standard size cable for immersion heaters, ever since some numpty decided to do away with 7/029.
nope. bang in a 10.0mm.
but how anybody would even consider > 10.5kW is totally beyond comprehension.
My best mates 10.8kW shower ran off a 40Amcb in the airing cupboard, spurred off the immersion, spurred off a 16a radial socket circuit...for a bit. JB under landing went off like a grenade apparently
Did he keep resetting the 16amp ?
it was probably welded closed. like a 63A i had to replace some time ago. was constantly running at 100+A.
Reply to is it okay to extend shower cable or should i do new run. in the UK Electrical Forum area at ElectriciansForums.net
At a bread and butter job, loose socket, socket not working, change two lights. Sticking out rather like a sore thumb was this (I removed the wire...
Hi, I know it's best practice to run an immersion on a dedicated circuit but am I OK with the following A new heat pump is being fitted and it...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
Hello All Strange question for you, I know you don’t have crystal balls :) but can anyone give me any clue on the following… I have mid eighties...
