Discuss Is it worth paying an extra £1200.00 for 1 more panel? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
G
GOJO
Hi,
I have two quotes one for 11 panels (in a 8 / 3 configuration - a samil inverter on the 8 panels and a soladin inverter for the 3 panels) and then a quote for 12 panels ( 8 / 4 configuration with a samil inverter again on the 8 and 4 micro inverters on the 4) difference in the 2 quotes is £1200.00 is it worth the extra for 1 more panel and the micro inverters? Or is this a really stupid question?
Cheers, Jo
See your other post, depending upon the panels spec, you should be able to get 8+4 the Power one PVI 3.0 OUTD for the same price as the 8+3 and the two inverters if you haggle :)
Get one inverter if you can
Mastervolt or sunnyboy are two i can think of that can have 2 or more seperate strings on the one inverter (inverter costs under 1000 last time i bothered looking last year)
(Ive helped installs using these on 4kw systems)
I doubt that £1200 extra cost for just one extra panel will turn out to be worthwhile.
I have 15 panels and they generated 3300kWh last year, which is 220kWh per panel.
At current FiT rates (around 16.5-17p per kWh) one panel would "earn" £37.40 per year. It'd take 32 years in today's money to pay it off. Even allowing for inflation indexing of the FiT rate at 3-4% per year you'd still be looking at only £74 of earnings in the final FiT year and a payback period close to 25 years.
In-house usage of one-third of the power generated, at 14p per kWh cost of electricity, adds another £10 of savings per year.
All-in-all, an extra panel at £1200 would probably only reach payback around year 20-22, so would fail to earn its keep.
So in summary: I would not spend £1200 for an extra panel. I might spend up to half that which would give a payback period a little over ten years.
Reply to Is it worth paying an extra £1200.00 for 1 more panel? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all. We have had 7x 400w solar panels for a number of years now on our roof which is se/nw facing end terrace. 4 on se side 3 on nw side...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Hi all, total newbie to the forum. I sincerely hope that those in the know-how would be able to assist me. On my semi-detached house we have an...
Hi everyone. The owner of the business I work for along with myself have created a DIY inverter setup that is giving us some issues. We bought...
