Discuss Is there a standalone weatherproof timer? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
I am looking for a weatherproof timer to switch a 2 gang socket on/off.
I can find plenty of single sockets that incorporate a timer but I cannot find one with with 2 sockets, or just a separate weatherproof timer (suitable for sockets, 16A) that I could then use to switch a standard 2 gang weatherproof socket.
Does anyone know if anything like this is available?
If at all possible it's far better to put the timeswitch indoors earlier in the circuit, the best way to weatherproof something is to not put it outside.
If it has to go outside then a Din rail mounted timeswitch in a weatherproof enclosure would do the job.
Agree
Reply to Is there a standalone weatherproof timer? in the UK Electrical Forum area at ElectriciansForums.net
My customer wants to be able to switch his heat pump (3.5kW) for his swimming pool on and off remotely, he also wants to be able to set times for...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
Hi, I am a basic DIY'er, with basic electrical skills, NB, I can change a plug/fuse, change a ceiling light fitting, change a socket face plate...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Looking for an outdoor centre off switch (not retractive) and find myself short on options. I have a lot of Gewiss enclosures to which a centre...
