Discuss Is there a way to move around a drilled hole in ceiling without drilling another one in the DIY Electrical Advice area at ElectriciansForums.net
LED is just another step in the lighting story.
Something else will be along in the future to replace it.
Don't ask me what as I dont' know, but I wouldn't be suprised if it's already under development.
It is in development
The Russians are redeveloping halogen technology to be more efficient than LEDs
Reactions: DPG
Sorry for the confusion! That light bulb and the fitting is a temporary one. This is what the back of the light I want to put looks like:
So effectively I need 2 suspended screws that distance apart. I am going to get rid of the existing fitting and bulb.
As suggested by the other members, I might eventually end up drilling a hole if nothing works out, but I want to avoid it if I can - mostly because my previous (first) attempt at drilling concrete was disaster.
Thank you everyone for the pointers! :)
Are you saying that your ceiling is concrete?
I did some more looking around and this is close to what I imagined:
aliexpress.com/item/32683522633.html
But I need a flat version of this, and something which I can easily order within EU (preferably buy quickly from a store in Sweden), but looks like there isn't something obvious/standard available.
@Megawatt yes it feels like concrete or some hard building material. I cannot say for sure, but it's not wooden and hard to drill (at least with my multipurpose drill).
@Spoon sorry about not being clear earlier but that's how most of the buildings in the 2 countries I have lived are. Neither am I a professional (in fact a noob!) and am doing this just for our house. What are ceilings in UK mostly made of? Curious!
Also I thought the initial figure I created specified the requirements clearly and not sure if the material of the ceiling really matters for the solution I am looking for?
Most ceilings in UK houses are plasterboard. Typically fixed to timber joists, but sometimes to metal framing instead.
Which is why we struggled to understand why you did not just drill another hole!
Concrete is occasionally used, more typically for blocks of flats.
Hello everyone!
Is there a way to move a drilled hole in ceiling slightly to the right without drilling another hole. I need to suspend a light ceiling lamp and want to avoid drilling another hole if possible. I am imagining something like this:
So effectively I am looking for a flat horizontal strip which has support to put in screws anywhere. Is there something like that which already exists? If yes can you please share a link/name? I tried looking but was unable to find anything. The lamp is very light and there won't be any stability issues.
Thanks a lot!
Cut a strip of the ceiling off the width of the distance you want to move the hole. Then slide the whole ceiling across. Job done ;)
No problems mate. See @SJD post above for how the majority if ceiling are built in the UK.
I thought what you were after was going above the ceiling, in the void.
What problem did you have with your first attempt?
Forgot to add that the advantage of this method is that the strip you cut off will match the gap at the opposite side which is left after you’ve moved the ceiling over.:cool:
I think your status should be upgraded from trainee to genius.
If it were me I would drill 2 new 4.5mm holes @ 50mm centres & a 20mm hole in the middle of them for the cable on the light fitting. Then fix using the existing ceiling holes.
Thanks @SJD!
@Stubob interesting approach. Though the LEDs are stuck to the upper surface, but I can try to explore if there is space for 2 new holes on the light itself.
@FatAlan haha! Your genius approach might not work for me given that you are assuming that the ceiling is composed of 2 surfaces. For me it's just one concrete layer. I cut a strip and move ceiling, everything stays as is, and just move sideways :p
You probably need to come up with another genius solution ;)
Reply to Is there a way to move around a drilled hole in ceiling without drilling another one in the DIY Electrical Advice area at ElectriciansForums.net
A rose in my 1970s kitchen ceiling became loose (one fixing screw had been inserted right on the edge of the hole in the ceiling) and when I...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
Hi, I live in a property built in 1911. It has had asbestos artex applied to every ceiling in the house. I am currently creating a new...
Hello all, I'm renovating my kitchen and had a question about running wire around ductwork. In attached pictures - I need to have a receptacle...
