Discuss Is this a dimmer switch. in the Lighting Forum area at ElectriciansForums.net
Just moved home. Does anyone have any information on this switch. It looks like a dimmer. Its feeding 3 sets of halogen spots but isn't working properly. Bright then dark etc etc. I cant find any info on it anywhere. Please help.Is this a dimmer switch. Dimmer (2) - EletriciansForums.net
Never seen anything like that before.
Does any of the switch move?
Do the vertical yellow lines down the sides glow in the dark?
The black square may be a receiver for a remote control?
You could, if the power has been isolated, pull off the cover/unscrew from wall and look for a model number or manufacturer printed on it somewhere. Then google is your friend.
I am certain that is an IR controlled dimmer switch. It should have a TV type remote for it.
[automerge]1573581689[/automerge]
Look on here you will see one.
Hello. The switch moves on/off like a normal light switch. The vertical lines don't glow in the dark. The red square being a receiver makes perfect sense unfortunately any remote hasn't been left by the previous owner if that's the case. I think pulling off the cover etc may be my best option. Many thanks for your help.
Before you start.....
Remove the coloured strips by pulling out. There should be two screws under them holding the cover on.
[automerge]1573597210[/automerge]
I have attached a scan of the user manual.
[automerge]1573597316[/automerge]
Is this a dimmer switch. 20191112_220530 - EletriciansForums.netIs this a dimmer switch. 20191112_220530 - EletriciansForums.net
[automerge]1573597348[/automerge]
Is this a dimmer switch. 20191112_220525 - EletriciansForums.netIs this a dimmer switch. 20191112_220525 - EletriciansForums.net
  • Select remote dimmer manual.pdf
@Tomnoddy
If you want the remote and two more dimmers, let me know.
Thank you so so much for your help, Timbo. That's awesome. Yes I would like that for sure. Can you let me know what to do now regarding this. Kind regards Tom.
[automerge]1573670110[/automerge]
Well done @Timbo
That’s a winner right there
Thanks for your help little spark...really appreciate it.
[automerge]1573670336[/automerge]
That deserves a ?
Thanks for your help westward10..really appreciate it. Timbo awesome for sure.
Reply to Is this a dimmer switch. in the Lighting Forum area at ElectriciansForums.net
