Discuss Is this lighting wiring odd? in the UK Electrical Forum area at ElectriciansForums.net
56A7C0FE-DFF3-4804-A10E-6B51B50E52EB.jpeg Gone to replace a light in our house and found the following setup. Given its the old colour scheme I’m a little confused which I need for live and neutral given all the red are looped. The black with the tape is the switch so does this go in neutral or live on my new light (it has a live, neutral and earth fitting) and the other non taped black go in the other - earth is obviously for earth - thanks for any help
Well quite simply - you need to understand that type of wiring. The black cable with red tape on it is the switched live - ie the cable that comes back from the switch. The red cables are your permanent lives which supply live to the next light. However, I think you need a better understanding of this wiring to do any work
That s a stadured set up for a lighting circuit , the cables need terminating correctly though, I dont like all that bare coper on the permanent lives (the 3 reds) those reds will still be live with the light switch turned off . so make sure you turn of the lighting circuit at the consumer unit and test its dead before you touch it, if you are not sure if the circuit is saftley isolated then i would suggest to get a spark this would be a simple job and should not cost much to do just a call out charge , but if you do not isolated the circuit propley or connect up the light incorrectly you could get an electric shock or worse case , kill yourself or someone else, not trying to scare you , just want you to be safe
Reply to Is this lighting wiring odd? in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
I’ve got the following setup on the stairway (picture included) https://pasteboard.co/15IoYrvn2VgA.webp https://pasteboard.co/2UzMaHCbs1iE.webp...
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
