Discuss Is this normal in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
T
topcat
Hi I have just been to do a EICR just some of the points I found in 30 mins CU old with on RCD only held on wall with 1 screw
all sockets surface mounted at least one screw missing out of most no earth to any of the sockets at all on earth to the CU.
Looked like their was a earth but if their was it was in 2.5 mm and could not get any reading from it at all. One light switch with 3 core but only 2 used one still live.:banghead:
So how was the weather in Sunderland today??
Could not get earth reading from 3 sockets on 1st floor No bonding to pipe work any or meters.
Extra sockets run all over the place Shower 8.5 kw on 6mm. extra lights and stuff run all over the place began to think it was a wind up needs complete rewire to sort if you ask me.
Broken cpc then , just takes a while to trace
No bonding to pipe work any or meters. needs bonding then ?
Extra sockets run all over the place hardly unusual
Shower 8.5 kw on 6mm. sounds fine
.........needs complete rewire to sort if you ask me. not really , just a bit of time and effort to work through the defects
fair comment biff you are right they dont want me to fix the problems as they have another sparks who will do it ? Family but not part p from what was said Will need earth spike as well to get an earth as its on TT and could not get earth reading from earth cable.
no worries , just charge the customer for the inspection and move on.
life can be alot easier when you only do the PIR's and not the remedials.
as long as the 6mm is not cocooned in a foot of itchy-poo.
Have sent them the report they know I have said its unsafe and requires major reworking or rewire I think if I took out all the duff sockets their would be 1 or 2 in each room their in the first place their are so many things to look at that it will cost more in time than a rewire I think But They have not come back as yet they are away.
Do not think i will hear from them again but will keep you all up to date.
Reply to Is this normal in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
Hi all EICR today on a ground floor flat .. 1 issue .. At the consumer unit there was a 1mm core with its yellow (sleeved brown) in a 20A radial...
2nd fixing some sockets in an office today and we were talking about high integrity earthing, I've not got a clue what the sockets are going to...
