Discuss Is this possible to do safely? in the UK Electrical Forum area at ElectriciansForums.net
Trying to install a stove in my garage to use only the oven portion for small powder coating projects. I have a Nema 6-30 outlet on a 30amp breaker already in the garage.
I know a stove should be on a 40-50Amp breaker but I understand that would be needed if the oven and all elements were going at the same time. My thought is if I completely disconnect all the stove top elements to avoid them accidentally being used it might be possible. Is this wishful thinking or would it be possible to do this and also convert the 4 prong plug that has a neutral and a ground to the Nema 6-30 plug safely
It certainly needs to be 4 wire but I think 30 amp plug should hold just the oven. Good luck with your project
Work fine, just make sure the oven top disconnected and you should be able to use a smaller mcb
Reply to Is this possible to do safely? in the UK Electrical Forum area at ElectriciansForums.net
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
I have a new homebrew machine, but it comes with European cables and plugs. It's a 230v two prong to a C13 connection. I have a EV charger in my...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
Hi! I’d like to install a pedestal-mounted (230 V, 30 A max - programmable) EV charger close to my driveway, which ends about 12 feet away from...
4K
B
Prefix - I've tried to post this in automotive, but it would not let me. This may be because I have not been recently active. Apologies if this is...
