Discuss Is this the ground wire? in the Lighting Forum area at ElectriciansForums.net
Hello everyone, hope you are all safe and well. I am replacing a ceiling light and the new fixture has a ground connect but old one just the two wires. However there is this cable unused as you can see it's the one sticking out. Is this the ground wire? Thanks.
"fixture" and "ground wire" are terms commonly used by residents of the great US of A.
We in the great UK use the terms "fitting" and "earth wire".
would be a good idea also to trace the cable back to ensure that the earth wire is connected at tother end. but only a test using the appropriate equipment would confirm it's continuity back to earth via the Consumer Unit.
Also the visible copper on the screw terminal block (often called a "choc block" here, looks a bit like snappable chunks of chocolate) is not good, ideally it should be just inside the insinuated part of the block.
Us this ok?
Should I wrap insulating tape around the exposed copper wire?
So could I wrap insulating tape around the copper wire, or how else could I fix this?
The best solution is to have the cable prepared (stripped and trimmed length) so when it is in the terminal block the insulation is not too far out (i.e. it is not showing any exposed copper conductor).
Some times the reason it won't go in properly is the other conductor in the block is too long and is protruding in to the half you are trying to insert the new cable in to.
I have sleeved the ground wire and it now looks like this
I have tightened everything up and it looks like this. I just want to say thank you to everyone who helped. It was very much appreciated. Thanks!!
Reply to Is this the ground wire? in the Lighting Forum area at ElectriciansForums.net
Replacing a light fixture in an older home. The ceiling box has two cables, each with a hot and a neutral (photo attached). The old fixture had...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
