Discuss Is Wickes twin and earth any good or should I get Prysmian? in the Electrical Tools and Products area at ElectriciansForums.net
Have a read of the cable sheath, sometimes some of the bundles of cut cable they have available will tell you the make or brand...
It also depends on what you are using it for, and how much you need? if its just a meter or 2 then go for the best value, if a whole new circuit then the best your budget allows.
The quality,and therefore the cost,should be proportional to the length of time you expect the item to remain functional and trouble free.
A cheap lamp can be easily swapped for a better one...installed cables are a little more troublesome...
Reply to Is Wickes twin and earth any good or should I get Prysmian? in the Electrical Tools and Products area at ElectriciansForums.net
