Discuss Isolation lock off device in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
diditrain
Can anyone recommend an lock off device that works well on an 60947-3 main switch.
Most of them that I have seen come as a kit with lots of tatt thrown in that I do not need such as the padlocks, labels and cable ties etc, and are seriously overpriced?
You can get the type with the bent bit of wire, but then you need two sizes, one size for MCB/RCBOs and another for Main switches.
Some of the G clamp type have a pointed grub screw that digs into the toggle.
I don’t like them because they damage the toggle.
Those look good I might have to grab a few.
I used to use the screw type like these.
Miniature Circuit Breaker (MCB) Lockout w/ Adjustable Screw - https://www.lockout-lock.com/adjustable-mcb-lockout
But the top hinged CUs I use for domestic work mean that I can't get a screwdriver to the grub screw
Reply to Isolation lock off device in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Hi, after a bit of advice. Have tried a lot of plumbing and electrical shops but no one seems able to help. I have an Isolator/PSU 230v/12v. It is...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
m having a bit of an issue that is proving difficult to resolve. For 2 years I have been having no problems with my setup. I have a 3 zone house...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
