Discuss Isolator & consumer unit fitted in meter box in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
we've done this on lots of installs. IT was cleared by the DNO on the first, after that I didn't bother. One was also for my annual inspection and didn't raise an eyebrow then either.
As is said elsweher, if your meter is in your house, what then? If it's in your garage, what then? It's no different with the meter box, it doesn't belong to the DNO so you can stick what you like in there as long as it doesn't interfere with their kit.
Yes / No / Maybe - there are extensive other threads on RCB's ... TL inverters TT / PME systems ...... :13:
With this one the AC 6mm T+E is running in wall chase in kitchen.
Needs 30ma RCD to comply with regs.
If you can get away with just a main switch and MCB this would be preferable.
If it was out the bottom of meter housing, up the gable end, into loft and into isolator, all in SWA. An RCD wouldnt really be needed would it?
No it wouldnt.
I am not too keen on cables on show, just being fussy I guess!
If the customer had let me put the cable in surface trunking I could also have ommited the RCD.
We recently fitted a system with the CU + Gen meter in the meter box as it was next to the front door of the property. Running the cabling internally was not an option as the building was only 2 years old and the disruption internally would have been too great (limited access above main CU in house in airing cupboard with massive hot water cylinder sat on top of tongue and groove chip board) nowhere inconspicuous to site a sub-board in the hall or nearby.
We ran SWA from the meter box round the outside of the house and located the inverter behind the property on a north facing wall. DC cabling and 10mm G/Y run in 25mm black PVC tube up the wall to the soffit, 25mm copex through roof space to a roof vent; Tidy.
I don't have a picture of the inside of the meter cupboard after the installation, but I was really pleased how it turned out. Not sure how a smart meter would fit into the equation as I do not know what the dimensions are; I must admit that I had not thought about it at the time, but there is some clearance in there. The rotary isolator is adjacent to the inverter at the rear of the house so just gen meter and small CU in meter box along with DNOs cut out.
Monty
Thanks, being so new the roof was a pleasure to work on, there was even a spare roof vent for the cabling! Only downside was that every row of tiles had been nailed down!
Nice job IronLiver.
Smart meters are not massively bigger than most standard meters, apart from when comparing with the small types like the L&G 5235. Elster and Iskra 1ph Smart meters are about the size of a standard 3ph meter from a footprint point of view.
Thanks SibertSolar, I'll bear that in mind in the future. Does anyone know what the schedule is (if there is such a thing) for smart meter roll out in the SW, particularly in Somerset. Or does it depend on who the supplier is.
we're not really supposed to do it but its quite common and not a problem , its just the meter man over reacting.Its not their box anyway its yours!
Reply to Isolator & consumer unit fitted in meter box in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
