Discuss Issue with Keston C36 in the Central Heating Systems area at ElectriciansForums.net
BENBEST
I have a Keston C36 Combi boiler. Stuck in heating mode. I have changed the diverter motor as not moving to transfer across. This didn’t fix the issue. I’ve now changed the capacitor that drives the motor. Again nothing changed. Any ideas on what else it could be?
Without offending you, I don’t know how to put this.
DO NOT ATTEMPT TO SERVICE OR ALTER A GAS BOILER UNLESS YOU KNOW WHAT YOU ARE DOING.
Please get a registered gas engineer to look at it.
Do not worry, just call a good local registered Gas Safe boiler engineer and they will tell you what the problem is and sort it. They will carry out tests and replace any faulty parts. Guessing and randomly replacing parts will soon start getting expensive.
Reply to Issue with Keston C36 in the Central Heating Systems area at ElectriciansForums.net
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
So a customer changed his own stat and wired it wrong and blew 3/4 fuses. Then heating was stuck on so I changed the programmer and this resolved...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
