Discuss Issue with sockets/appliances help needed please in the The Welcome Forum area at ElectriciansForums.net
Hi, first post here, I've got an issue with my home electrics and need a bit of advice as to what may be causing it please. Bear with me as I know very little about electrics, anything more than wiring a plug or changing light fittings and sockets is beyond me.
So the issue is with appliances in the garage starting to blow fuses, the appliances being washer, tumbler and fridge freezer
They have all happily been plugged into a 4 gang extension cable in the internal garage for a few years, often all being switched on at the same time (fridge freezer constantly on, the others plugged in all the time and switched on when in use.
A few months ago the downstairs sockets went off and the fusebox switch had tripped and needed the switch flipping back on. I realised the garage appliances didn't come back on and I swapped the extension cable for a similar one (as I didn't have a fuse handy) The new extension worked fine, I assumed it was a blown fuse
Everything was fine until the other day when the same thing happened, extension cable fuse blown again.
I plugged in an extension I use for gardening(4 gang 25 m reel extension with safety cut out button) and plugged all 3 appliances into that and that tripped after 10 mins or so.
I reset and tried it in different sockets and it kept tripping so I ruled out the sockets and thought it must be a dodgy appliance.
I unplugged the tumbler and it seemed to sort it out, The tumbler was old anyway so I decided to replace it and the washer and freezer have been running fine for 2 days, I actually bought another 4 gang 10m reel cable with safetey cut out and plugged them into that.
Today the new tumbler arrived which I plugged into the extension where the washer and freezer are plugged in and it's started to cut out again, I've now tried the new tumbler in the new extension by itself and it's cutting out.
Any idea what's going on? Thanks
Wetroom Store - Network Wetroom Suppliers
Strima
You have two large appliance running off an extension lead, you're overloading the lead causing the fuse to blow as they are not intended for this type of use. Please stop using this set up before you set fire to something.
You need to have these appliance running off separate socket outlets, what sort of power set up do you have in your garage? Separate fuse board or just a socket powered from your house socket circuit?
Pete999
Do theses extension leads come on a reel, if yes are you using them still coiled up? no recommended. Where, in the UK are you based? Also using an extension for multiple appliances is also no recommended. A visit from an Electrician may help, buying and replacing stuff, is a false economy. Posting your location may illicit an offer of help from a Forum member.
  • #4
Thanks, I've just done a bit of reading around the internet and it does seem I've been a bit naive here in running 3 big power items on the same extension. How the heck I've got away with it for years is amazing.
It's a normal double socket in the internal garage
I only have this one double socket in the garage and those 3 appliances, could/should I run a short 2 gang extension to run 2 appliances at the same time and have the other plugged in the wall?
  • #5
Yes the extensions I've started using are coiled up, I used to use the normal flat white extensions but they blew so only had the coiled garden extension 25m, I thought the safety cut off would be a good safety feature so bought a 10 m one too. I'm based in NE England
Pete999
Would be a abetter option to have some extra socket outlets added, to avoid using extension leads.
  • #7
I'll certainly look into this however in the short term I'm going to try and get the fridge freezer turned so the cable plugs straight into the wall.
The washer and tumbler won't reach so would it be ok to get a short extension and run them one at a time so as not to overload things?
telectrix
Mentor
as the other old git says ^^^^^^. get an electrician to add 1 or 2 more sockets. (assuming the supply to the garage will handle the load.). the reason you've got away with it before is that maybe the appliances were coincidentally not all on heat cycle at the same time. bear in mind that washers and dryers each pull around 10A when heating.
Strima
If these appliances are also quite old they may well be drawing more current than they did originally as things start to wear out.
telectrix
Mentor
so that's why my leccy bills have gone up. i must be drawing more current as i wear out. :D:D:D.
  • #11
Good point, the fridge freezer is over 10 years old, the washer about 3 years and the tumbler was well over 5 years, looks like I've replaced that for nothing though it was getting tatty
Pete999
Stop wasting Money and get your Garage sockets sorted, Agree with what the first old git said
T
Toneyz
was this our last night out, pete? when we picked up those 2 slappers?
Who is who?
  • #17
Whilst I'm here I may as well ask about another strange electrical thing I've had intermittently for a couple of years.
When I switch the garage light off it sometimes disconnects the sky Q box in the living room. Though I was going crazy but it definitely does it.
It doesn't put it into standby, the box still has the green light on but my TV brings up the "no source check connection" screen as though the box had gone into standby. I have to press the power button to actually put it in standby (yellow light) then again to put it back on for it to work again.
This only happens with Sky Q source and only when the garage light is switched off not on, it never happened when I had Sky HD and must happen 20% of the time, it also sometimes nearly does it, ie flickers if that makes sense.
I contacted sky but they're not really interested.
Thanks.
EDIT I've actually had the Q box swapped but no joy
  • #18
https://www.screwfix.com/p/masterplug-13a-4-gang-switched-surge-protected-extension-lead-1m/1601g
Would that be acceptable to have the washer and tumbler plugged into if I only run 1 at a time?
Deleted member 26818
I had a similar situation with a touch light switch and a TV.
Turning on the light, could cause the TV to change channel.
Standing between the switch and the TV prevented this.
I assumed the spark produced by using the switch, caused a burst of IR which matched the code from the TV remote to change channel.
James
Mentor
Supporter
If you have a medium wave radio, tune it into a weak Chanel and listen when you turn the light off.
You might hear a crack or a pop, this would suggest the light fitting (possibly an old fluorescent light) is generating some electrical noise that can cause strange thing s to happen with electronic devices and computers.
remedial
Trainee
You dont need a new extension lead. You need more sockets. Your problem is that your double socket is rated at 13A. I believe you said that the fuse in your orignal extension lead blew. That would have also been 13A. So basically you are still overloading your socket if you run all the appliances.
In order to comply with BS1363, double sockets should be rated at 20A.
MK sockets and I assume other manufacturer’s double sockets are rated at 26A.
  • #23
Ah ok thanks. I think I'll be getting extra sockets but in the meantime what's the best way to manage a permanently running fridge freezer from one socket of the double and either a washer or a tumbler in the other, neither the tumbler or washer can reach the socket without a metre extension
  • #24
This is the socket, standard double one says fenby on it, house is 18yr old DSC_0027.JPG
  • #25
Thanks, it is a fluorescent light in the garage, this may explain it
pirate
That's a matter of a crownwheel, Tel...
Sorry, a pinion...doh!
Pete999
Not sure Tel which one am I? memory is not what it used to be, who are you again?
Electrical2Go - Online Electrical Supplier
Reply to Issue with sockets/appliances help needed please in the The Welcome Forum area at ElectriciansForums.net
Top Bottom
