Discuss Issues with wiring up a dimmer and switch for LED downlights in series in the DIY Electrical Advice area at ElectriciansForums.net
Mr Ziggy
Hi all
I am a newbie from Australia to this great forum.
I need some advise with wiring up a dimmer and switch for my LED Down lights in series.
I have run a mock up from the extension cord with some success. But still have issues.
The dimmer instructions diagram indicates one red connector from the dimmer to 1 on the switch and the other to the neutral wire connected at the inactive loop connection point.
I did that but still have issues as it hums when installed.
Here is the diagram from the manufacturer.
I have tried a few options but something is wrong.
I plan to run this set up in my man cave/shed rebuild in the near future.
The voltage is 240volts @ 15 Amps
The dimmer is a Diginet Rotary LED Dimmer
the downlights are
NLS 20094 | 13W DIMMABLE 3000K WARM WHITE LED DOWNLIGHT​
Any help from you guys would be greatly appreciated.
It eating at me not being able to work out this maze.
Thanks in advance.
Mr Ziggy ?
Hello.
It’s a bit of a fine art trying to dim LED lights, as not all are compatible with each other.
in your case, I think the dimmer is only rated at 12v, whereas your input voltage is 240vAC.
I’m afraid you’ve fried your dimmer. Surprised the humming noise isn’t smoke and crackles.
Hello.
Thanks Littespark for the reply.
Could that be the case. You sparkies know better i guess.
On the specs it says:
Specifications - Diginet MEDM LED Dimmer​
Power Range2-400W (see data sheet below for details)
Voltage220-240 V AC
No where on the documentations does it say 12 volts.
I am puzzled.
School me on this please.
Look forward to learning heaps.
Mr Ziggy
also found this little write up that says:
"...So what we need to do to install the dimmer, is remove one of the switch mechanisms and put the dimmer into where it was. And just use your pliers to pop that out. As you’ll see, the dimmer just clips in nice and firm. You’ll see on the back of the light switch here there are a few different terminals. So the one in the middle there, that’s your common terminal, that’s where your permanent power supply goes. It’s always 240 volts....
Sorry, my mistake. I was reading 12v off the side of the dimmer in the picture.
Its early morning here, give me a break, lol.
In that case, have a look at your wiring diagrams.
your live feed goes to C of switch, then L1 of switch to input of dimmer.
Output of dimmer should then go to your light fittings, without being connected to the switch at all, separate connector.
Neutral from lights to neutral feed. Again, not connected to the switch itself.
The loop terminal on the switch could be used as one of these separate connections, as there’s no interconnection between it and the other parts of the switch.
There is no need to connect anything to L2, especially not the neutral.
ok
like what was shown in B
still does not dim nor turn of now .
Need help. ?
Mr Ziggy
Your dimmer is probably fried, connecting across L and N.
You have connected the light straight to incoming L feed.
Take the light connection out of C and put in a separate connector with the output of the dimmer.
Timbo
Thanks for you reply.
Just to get it clear, like this ??
No mate.
Both your diagrams were wrong.
The dimmer must not be connected to neutral. It is a switch like any other.
live in, and live out.
Connected between live and neutral, your dimmer has snapped, crackled and popped it’s way into the electronic afterlife.
Your the man ! ?
Its Black and White now, thanks for being so clear Timbo.
Have a great day buddy !
I learnt heaps ?
Reactions: DPG
So just to cap this off for others who might need it, it looks like this
Cheers
What a lovely day
Thanks again to Timbo and the crew at EF for the help !
Reply to Issues with wiring up a dimmer and switch for LED downlights in series in the DIY Electrical Advice area at ElectriciansForums.net
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
I have a led panel that i want to dim. It is dimmable but without a dimmable driver. I have a dimmer module and a dimmer switch as shown in the...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
The G4 110V 3W dimmable bulbs I purchased work with a dimmer. I can brighten them and dim them, but when I turn the dimmer off, the LED bulbs...
