Discuss JCC LED strip light..... does anyone know please ? in the Australia area at ElectriciansForums.net
sythai
Just pricing up some bits... and was wondering if anyone has fitted any of these before?
JCC Lighting: ragoza (IP Version)
As I was wondering if they can be cut down to size ? The reason being it will be going into a couple of recesses, I know on the non IP rated version you can... but not sure with this ?
Thank u,
Sy
Hi there...
Didnt end up supplying the materials in the end, the customer brought an Aurora kit very similar.
Which I cut to length (within 150mm) and then you just put an IP cap on it and heatshrink (all supplied in kit)
Sy
Reply to JCC LED strip light..... does anyone know please ? in the Australia area at ElectriciansForums.net
Whilst having some building work done we discovered a stone lined well under our new kitchen floor , It is 25' deep and hand dug (through shillet)...
Hello, We moved into our house 2 years ago and until recently the kitchen lights worked fine. The LED strip lights are on a dimmer switch, when...
Hi, I have bought a LED Lighting Strip (20 metres) to sit inside some Screwfix coving for my bedroom. Although it will be controlled by the...
Hello, I am currently DIY upgrading a caravan with my girlfriend but need some advice. The (very old) 230VAC to 13.8VDC power supply broke down...
