Instyle LED Lighting Specialists UK
Discuss jim - problem with the insulation and pvc cables in the Commercial Electrical Advice area at ElectriciansForums.net
J
jim murdoch
Hi Guys
I am working in a house at the moment which is geting refurbished the joiner who is installing Kingspan insulution tells me on his last job there was a problem with the insulation and pvc cables and the bcables had to be kept away from the kingspan insulation. has anyone came accross this before ????
R
rumrunner
  • #2
hi jim,
yes ,"styrofoam" and pvc dont mix well,im not sure if the cable insulation would melt away compleatly in time .but it does get sticky,not sure as to a solution,best to play safe and price for o bit of pipe or trunking ,maybee
M
Minky
  • #3
Came across this one recently,Kingspan does have a long term effect of polymer migration between the insulation of the cable and Kingspan.
Cause is insulation breakdown on the cabling leaving conductors without any insulation surrounding them and then operation of the protective device.
Plastic trunking and pipe is susceptible also
Solutions are metal conduit,trunking where applicable,or bare MI cable.
One other solution that i believe in use (never used it myself) is LSOH cable.
Although LSOH is more expensive it is certainly cheaper than a civil action.
G
Grae79
  • #4
From what I know it's only the polystyrene insulation you have to be careful of not the Kingspan type. Was trying to find the relevant reg as i've seen it before, but no joy...
Reply to jim - problem with the insulation and pvc cables in the Commercial Electrical Advice area at ElectriciansForums.net
Wetroom Store - Network Wetroom Suppliers
Top Bottom
