Discuss Job Sheet in the UK Electrical Forum area at ElectriciansForums.net
V
vernam616
Well as title really, im wanting a template or maybe a program to use on a PC/ipad/iphone for itemising the jobs im carrying out
all it needs to include is
time on job
materials used
what are you all using???
Dan
Hi
I just came across this post and I know it is quite old but other people might benefit from this program I've found called BusinessFlow Job Sheet Pro it's a basic job sheet program, keeps your customer details and all the site addresses for that customer, templates can be altered to suit your business and created in pdf. You can have multiple different templates for different parts of your business. It suits our small electrical business down to the ground. It for PC's not mac
Hope this helps.
This is GREAT i was looking for a simple job sheet template also so have tried th Business Flow jobsheet pro above and got a free triel so will let you know how i get on. :)
Reply to Job Sheet in the UK Electrical Forum area at ElectriciansForums.net
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
Currently using paper job sheets. Does anyone use an app or alternative. Looking to give my employees an iPad and send jobs that way
Hi guys. It would be really useful to run this past you and get a consensus/input from you for what would be a realistic amount to charge for an...
Just had a simple kitchen light not working job, one of the fittings with the 4 spotlights on it. Took the fitting down to check if there was...
