Discuss Joining 16 or 25mm Earth Cable in the UK Electrical Forum area at ElectriciansForums.net
Hi any recomendations for products which I can use to join Two 16mm Earth cables. Going in a Fairly inaccesable place so trying to avoid Screw based products. Need to move an bonding cable for Copper pipe as boiler been relocated
Reply to Joining 16 or 25mm Earth Cable in the UK Electrical Forum area at ElectriciansForums.net
Curious about supplementary bonding, I have these two 4mm Cables loose and not connected to anything in my parents house. I presume they are for...
Electrician has done rewire, plumber with not much space has some central heating and hot water pipes touching in some places. See images...
Hello. New member here. Electrical enthusiast. I am at a friend's house in the Bahamas and decided to look at the load center in the house, which...
Disclaimer: I'm not going to attempt this job myself, I want a professional to do this job properly since I consider it non-trivial and need it...
Hi all, Would like some advice on the below. Context: Rural French domestic installation TT system Earth rod is situated inside the property...
