Discuss Joint cables inside back box? in the UK Electrical Forum area at ElectriciansForums.net
M
Mynamesmatt
I have one double socket in my kitchen (its part up the upstairs ring) ...and i need to change it to three doubles
Is it ok to use the double back box that is currently in the wall, to joint and extend the ring (and place a double blank plate over) then chase down and fit three doubles?
If so what type of connectors should i use, wagos?
Be nice ...........
im a qualified electrician! the original socket is far too high above the worktops, just all needs re-jigging really
thanks guys!
also, i came across a lighting junction box under the floorboards.. all the terminals inside were being used by live/neturals and so someone has brought the earths OUTSIDE the jb and put them all into a chock block.. anyone ever seen this done? hmmmmmmmm
Sorry matt, didn't know you were a qualified electrician. I'm surprised you are asking about extending an RFC in that case. Not part P tho?
In answer to the JB question, yes, you will find that method used throughout thousands of homes. Not good practice, and one which I hate, but out there nonetheless.
You've got it dead right matt, nice picture. Doesnt matter what you have behind the blank plate (crimps, terminal block, wagos) its all good although I love wagos these days. I wouldn't worry too much about that Part P nonsense, its your gaff and if you know what you're at then crack on.
On the subject of wagos
Anyone who has never use a wagobox/connectors please please give them a try you dont know what you are missing out on.
Picture this: 4 T&E's and 2 3 cores hanging out of a 70mm downlighter hole all need connecting together in an enclosure that will fit back through that hole.......major headache right...not with a wagobox and connectors. Literally takes about 10 minutes and only tool you need is cutters, no tape no drivers nothing.
Awesome awesome awesome
so what if its 5A connectors....as i found the other day in a similar scenario?
Thanks for the support Dave.
if it's exactly above the new socket, cut a bit of metal capping down and place it over the connections then plaster over it. I see no reason why that can't be done because it's still in a safe zone, that's only if your using maintenace free connections though
I don't like that! I know it's ok cause it's mf but there's something about it I don't like and would never do myself
I can't believe that you guys are telling a DIY'er how to do notifiable work in a building regs special location.
Lucas, many thing "can be done", but plastering over push connections does not make the joint MF.
Part P is a load of old tosh. It will never stop people doing work in their own homes. It's just another government solution to fix a problem by extracting money from people at the same time
You may think it's tosh and I may think it's tosh, but it is the law. Very irresponsible to suggest to someone on a public forum to ignore it.
^^^^^tend to agree^^^^^ .....because it is a tad surprising that a qualified electrician needs to ask how to extend a RFC. If the OP was competant enough to ignore part p he wouldnt have to ask how to do the job.
I've been known to ignore part p but then I've been extending RFC's for decades before part p was a twinkle in the governments eye.
New posts
Reply to Joint cables inside back box? in the UK Electrical Forum area at ElectriciansForums.net
Good evening. Currently sorting out my girlfriend’s flat for rent. I’ve found all sorts of bad electrical work. Can anyone advise if this is an...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hi All, As a householder I'm keen to add a double socket further along a wall to extend access in a different corner of the room. I'm connecting...
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
