I came accross a ring circuit that was split into two ring circuits up and down stairs.
All connections are under floor boards and accessible because floor board above each connector is not nailed down, each joint is mentioned in red pen on the floor board. There are joints with screw connectors connecting wires going to each socket.
This I suppose helps as no need to dig up the wall for replacing wire going to each socket.
The questions : is this allowed (as they are all accessible)? and each joint must be increasing the resistance so is there limit to number of joints?
