Discuss Jubilee line light switch in the DIY Electrical Advice area at ElectriciansForums.net
I meant is there a loft space..
Because you are controlling a downlight then it makes the job very easy..
Is the wall plasterboard? That will be the only mess needed to be made..
What you need is an rf binary input module, this will be wired into the new switch..
Rf receiver installed in line with the downlights..
Why jump to rf as a first solution? A hard wired solution is almost certainly possible eliminating the need for any wireless connections, hard wired connections are inherently more reliable than wireless.
A hard wired solution will be possible but due to the lack of information available, the rf solution I suggested is a guaranteed hassle free solution.
It is prone to problems as is a wired solution but the rf solution I suggested would be a lot less hassle.
Reply to Jubilee line light switch in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi, I was ironing and lost power to the bedroom and bathroom. All outlets and lights. I checked the box and reset breakers still no power. I...
Im trying to make a Star Wars Prop for a course project where the dealine is comming up very fast in days and I need to do the report so really...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
