Hello,
I have two almost identical circuits of outdoor 12v lighting setup in my garden, each running off a separate 20W 240v-12v transformers (12v Waterproof Transformer (Various Wattages) | 240v - 12v | 10W - 150W - https://www.lumenalights.com/shop/product/12v-waterproof-transformer-various-wattages/). Each circuit has 5 x 12v LED lamp fittings, connected using IP68 3-way connectors (
https://www.amazon.co.uk/ATPWONZ-Ju...19233&sr=8-7&keywords=ip68+junction+box+3+way
) and 0.75mm 2 core 12v cable (2 Core Rubber Cable Reel (12v) - 0.75mm² - 25m / 50m / 100m - https://www.lumenalights.com/shop/product/0-75mm²-2-core-rubber-cable-12v/). There is approx. 1-2m between each connection. One circuit uses recessed light fittings (Decimax - 12v Recessed Light – Stainless Steel (304) - 12v Plug & Play - https://www.lumenalights.com/shop/product/decimax-12v-recessed-light-stainless-steel-304-12v-plug-play/) buried in chippings, the other uses hanging light fittings (Pergolux 12v Garden Hanging Light - 'Earth' Brown Aluminium - Lumena - https://www.lumenalights.com/shop/product/pergolux-12v-hanging-light-earth-brown/). Each light fitting holds a 3W LED bulb, so the total wattage on each circuit is 5 x 3W = 15W.
These were all initially working fine; however, recently both circuits have started to cut out, as the transformers are overheating after about 15 minutes. I bought a clamp meter to measure the current on each circuit and am seeing some very odd behaviour. Sometimes when I switch the lights on, the reading is around 1.4A, whereas at other times it shows as around 6A - this is when the transformers start to heat up. Strangely, by switching off and on again the 6A reading will sometimes drop down to 1.4A and vice versa; however, once on, the current stays around the same level from then on - so if I switch on at 6A it will stay around 6A and the transformer will overheat, whereas if I switch on at 1.4A it will stay around that level and will not overheat.
Can anyone offer any suggestions as to what might be causing this behaviour? I there likely to be something wrong with the configuration of the circuit or could a fault with any of the components which may be to blame?
Any help or advice extremely gratefully received. I can't figure this one out.
