Discuss Junction box recommendation in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
I have some up and down lights to install either side of a front door. The only possible supply I can take is from the light just passed the door inside the hallway.
The light installed is like below. I plan to fix a JB on the cieling, pick up a feed from the downstairs lighting circuit and then run a small piece of mini trunking to the switch.
What junction box could you reccomend that would look unobtrusive. I really dont want an ugly square JB sitting on the ceiling and then the light hanging from it.
fit a dry line single box in ceiling. do your joint, then fit a blank plate over. try and fish cable over instead of trunking. patch hole/s after.
Good idea. Would a round dry lining box be better?
your choice. easier to cut for round with the right size holesaw. just make sure youse clear of joist/s. or you could fit a plastic conduit box, just below flush, lid it and skim over. toatally concealed.
Reply to Junction box recommendation in the UK Electrical Forum area at ElectriciansForums.net
Ok. Can you cut a ring in half, add junction box, then run a spur off it? I thought it had to be from a socket? Mate of mine wanted me to see if...
The following light fitting from Dumelm takes GU10 but states "Dimmable No" but I can't see why with the correct dimmer switch and dimmable GU10...
Hi, looking for some ideas on this. I went to an address on Tuesday following a storm where property has been struck by lightning. When the...
Hi everyone. I hope this post finds you well. I have recently hired an local electrician to extend my living room lighting a few cm forwards...
My customer is having a wood burner installed. The stove installers have said he needs to get the 2 sockets that are directly behind the new...
