Discuss Just for Tel and anthonybragg in the UK Electrical Forum area at ElectriciansForums.net
Still got some, somewhere I think.
I do believe that the fuse being used as the live pin, was in fact the very first plug top attempt at a fused plug top, note "I did say I believe so it is possible that someone, Lucien may be, may know different"
think you may be right pete. can't think of anything earlier with plug fuses. the biggest problem with the fused pin arrangement was getting the bugger back in the socket with silver foil out of a smoke packet round it.
Anyone remember that multi plug...…..Change the pins, 13amp, 15amp round pin or 5amp round pin. Move the face about and slide out and twist the required pins into place. I'm sure I've still got one, somewhere. Loads of properties being worked on in the seventies used to have round pin plugs.
edit..…….round pin SOCKETS
remember them.bet they'd not get a BS or a CE certification these days.
Plugs with fused pins are still used quite a lot at power stations. 110v Reyrolle plugs. They are available with either single or double fused pins.
Fitall plugs! Brilliant invention!
DS plugs also had a version with fused pins on L and N. John Ward again:
and as I mentioned in another thread, the Wylex ones ran vibrators and baby cookers
baby cookers need reporting to childline or social gestapo.
Especiakky if the socket was non switched!!!!
wow. pete speaks Scouse. there' s hope yet. repeat after me. egggs akkly, Anfield 4ever, wassup wack. get your mam to stitch this: calm down, calm down.
Reply to Just for Tel and anthonybragg in the UK Electrical Forum area at ElectriciansForums.net
Watchout and don't open the links Edit by Dan/Admin; the correct link Forum homepage has changed a bit -...
A friend sent me theses links to a 3D shot of inside the Edinburgh University high performance computing centre. This is a few from the most...
I was in a thread the other day and somebody showed me a screen shot of a, what I think if I remember rightly was, the "install EF to homepage" on...
The new homepage is a long list of the newest threads posted. (Or press HOME in the menu) So not replies. Just the threads. A constant flow. :)...
