Discuss Just Had A Power Outage. Should I Be Concerned? in the UK Electrical Forum area at ElectriciansForums.net
chicat
Just this Tuesday I had an electrician do an inspection and fixing and replacing some things.
Just today my house had a power outage.
Does anyone think this may have something to do with the inspection I had this Tuesday or was this just the usual appliances being overpowered (thus causing outage)? Thanks.
Did you loose ALL of the electricity in your house?
Pete999,
No, not all of the electricity. Most of the power was lost but not all per se. I remember my oven (and I think the light in my bathroom (where the box is located)) had power.
Johnduffel,
It doesn't happen too often so far. It was the RCD tripping. Flipped it back up now.
Davesparks,
I don't know because it was still sunny where the power outage happened. So I couldn't tell if my neighbours experienced a power outage or not. I don't think so, otherwise we wouldn't have needed to untrip the RCD. Usually if the whole neighbourhood experiences a power outage the power comes back on its own.
Hi - if you've had your RCD trip and you've had to reset it there is likely to be a fault. It's possible it's an appliance or it can be the wiring that's faulty. Sounds like you need to call your Electrician back for a look.
Pete999,
Johnduffel,
Davesparks,
Hi,what box is in the bathroom?
Wilko,
This is a stupid question but what is it that makes an appliance the cause of the power outage? Fuse overload? Too many appliances using up power?
Peg,
RCD Fuse board is what I meant.
in simple terms, an RCD compares the current flowing in the live and neutral and trips if they differ much. In normal circumstances it would be more or less identical as all the appliances use those conductors for power only.
However there is a third pin (earth) and also a lot of other conductive things around, including yourself, so if something is wrong thre are plenty of opportunities to find a current path another way. Obviously that's not a safe situation to be in.
If that happens, whether it be through the fixed wiring or through an appliance, the RCD will trip. This is to keep you safe and also indicate to you that there's a fault that may cause a danger so needs investigating.
QUOTE - [ what is it that makes an appliance the cause of the power outage? ]
Not always an overload, but with rcd's now days they sense leaks in electrical systems, imagine if you will a large water tank with a tiny pin hole in it, so that it still works as a tank, but just looses some water, the same thing applies to an electrical system and/or electrical appliances they can leak small amounts of power to ground. So possibly your system could have a small leak somewhere ?
I would very much doubt it has anything to do with what your electrician has tested and by coincidence you have an appliance which has developed a small fault which your rcd is detecting.
Pete999,
Johnduffel,
Davesparks,
Does your CU (fuse board) have 2 RCDs?
Don't agree 100% with this. If it was a thorough inspection that included removing accessories, it could be the inspector pushed an accessory back into place and caused minor damage to say a neutral conductor that will randomly cause an N-E fault and consequently trip the RCD.
Hi - as above, the RCD is checking no current is leaking to earth. It's an additional safety protection for us, because it's that current leakage that can be the cause of electric shock.
recently fitted a RCD in my underpants. no leakage so far. told you i wasn't incontinent; senile maybe. :mad:.
Back to the op .
Did the inspection flag any issues? How long was the spark in the house?
I'm not very technical when it comes to this, so I will try and explain things as clearly as I can.
When the electrician first came to try to diagnose and fix the power outage (was permanent then) a few months ago (this week Tuesday was his second visit), he told me something about the current in the second half of my house not being at a level as it should - he also remarked that this was something he expected from an old house but our house was only around 15 years old (he found this odd).
He also found the source of the power outage was in the kitchen. One of the sockets got some sort of moist (this socket was about a feet away from the stove). He replaced the socket and de-rated the socket circuit as a temporary fix (meaning I had to avoid using the washing machine, microwave, and kettle at the same time).
When he came back this Tuesday for an inspection, he found the wire (I think it was two wires stuck together) wasn't installed properly and was what caused the uneven current level as previously mentioned. He then briefly told me that in 2005 the Government had a law that prevents all builders from "doing whatever they want."
Before he left he told me that he will send me the test results and a certificate.
Hello Chicat,
It can be quite difficult knowing how to explain a technical issue to a non technical person. I hope that your last posting demonstrates that a poor job has been done explaining, not that a poor job has been done.
I am not sure if anyone here is going to have anything helpful to add without seeing the test results you have referred to, even then a visit to investigate is likely to be required.
How did you choose this electrician? The fact that you are posting may imply that you do not have much confidence in him.
If you are after a second opinion or a fresh pair of eyes then post your location to see if anyone on here is local to you
Mhar,
When we had a permanent power outage earlier this year I just called a service and he just happened to receive the job from his employer.
After the first visit he gave me his mobile number and months later I contacted him to arrange an inspection (after two previous unsuccessful arrangements with other electricians - one never turned up and one never gave me a time and just showed up without us preparing).
I didn't mean to show a lack of confidence in the electrician. I'm just frustrated that a power outage has happened even after an inspection (which only took place earlier this week) and I don't know what the problem is this time (going to investigate if it's just a faulty appliance). I'm living with my parents; they're old and don't have that much money, so any visit from an electrician would be at their inconvenience.
Personal annoyance aside, I have been looking around my house for a bit and noticed 3 (unused) sockets turned on. I believe they've been on for 5 days since Tuesday. Do you think they could be the reason why the RCD tripped?
Also I'm based in North Somerset, so 20 or so minutes away from Bristol. I can also post test results here when I get them, if that would help anyone here.
Reply to Just Had A Power Outage. Should I Be Concerned? in the UK Electrical Forum area at ElectriciansForums.net
I'm unsure if I should be an electrician or maybe another trade is better. I have basically completed my first year of a foundation in...
There was always talk of teleswitch transmitters being switched off. Does anyone know if that is a thing, or whether it’s been done? I was at a...
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
There is power flowing. I have checked with multimeter. One light on the line works..even replaced the switch it is connected to. Rest of line...
