hi guys i really need your help on this one,
I just sat the 2395 inspection and testing certificate( replacing the old 2391), but it was really hard and wanted to know if i could sit the 2391?
But does the 2391 still run on the same format as asking the questions , i.e, procedure for continuity of ring circuits, diagram for an earth fault loop for a certain scenario, responsibilites/competences of an inspector, why initial verification is required and to verify what..etc.
Because i've done 6 previous 2391 exam papers and they always ask the same questions but for different scenarios.
the 2395 was completely different as there was no earth fault diagram to draw( an easy 15 marks), this time they asked why a continuity of ring final circuits should NOT be done, they wanted 10 inspections for an insulated consumer unit(BEFORE the cover is taken off) and the dreaded procedure for an earth electrode test came up!
Many thanks.
Many thanks.
