Discuss Just saw this in the new ‘shower electrocuted’ in the UK Electrical Forum area at ElectriciansForums.net
It may be old @Tes369 but it bears repeating again and again about the dangers of unsafe electrical installations. People need to know about this. Personally I have never accepted electric showers as safe and always feel apprehensive if I have to use one. The thought of electricity and water together just never seemed sensible to me and it never will. My sincere condolences to the surviving Mother who must be devastated.
I did a pir on a student let a while ago and found 2 wall mounted showers basically in ‘cupboards’ wired in flex to a socket in each bedroom
Guess what , no rcd what so ever. Not on the socket and not in the consumers unit
This place was refurbished around 2015
Really sad and totally avoidable, I was always taught that if you see someone getting an electric chock then you kick them away rather then grab hold of them.
You knock them away with a lump of wood or something similar ideally, ie. non-conductive. Obviously the first thing to do is to kill the power unless it is not immediately possible. Sorry, I know that bit's obvious.
As you said, non conductive I should have added not barefoot, even a towel would help but I suppose it was a gut reaction to grab the child.
Reply to Just saw this in the new ‘shower electrocuted’ in the UK Electrical Forum area at ElectriciansForums.net
Hello, I am in the process of training to be an electrician and have a question. When filling out a EIC for a new circuit am I required to test...
Hi, I`m looking for an advice. I have an electric shower that I`m not using due to boiler changed to combi and added shower over bath feed by a...
Hi all, I replaced my old Electrolux oven which operated with a 13 amp plug. The new Kenwood oven I ordered says a 16 amp (Requires hardwiring to...
Hi all I have a small DC motor that I pulled off from an ABS car module and need help identifying some parts in order to hopefully rebuild it. 1...
Please advise a part number and quote for the 2 screws at the top of our Triton "T80Z fast fit" Shower.? (Also please advise on the type/length...
