Discuss Just tuck it in the back of the box wahey in the UK Electrical Forum area at ElectriciansForums.net
I'd enjoy inspecting one of these guys :)
Been up in a roof this morning after storm Doris leaks and RCD now not holding. Fixed 3 junctions that were not in a box and full of wet ceiling ichypoo muck. At least there was an earth and an RCD.
Part 1?! How many videos does it take to join 2 cables, just stick those 2 lighting cables in a J201 and chuck it on top of the insulation. :D
Reply to Just tuck it in the back of the box wahey in the UK Electrical Forum area at ElectriciansForums.net
Has anyone used or fitted this type of back box ? It is a 1G & 2G
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
I find myself in the position of having to fit a few back boxes in to plasterboard. In the past for the odd one I just used a hand plasterboard...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Could the sun’s heat on a caravan mains supply cable cause the fuse/circuit breaker at the meter box/supply end to trip?
