K
KingKenny
Hi everyone - First post on here from a newcomer to the trade, so please bear this in mind when replying. ------- I was carrying out an Inspection and Test on an install today and wanted to get a ZS reading at a light switch. I couldn't get a good enough connection with the crocodile clips, so had to use probes. ----------------------------------------------- My testing kit is a Kewtech KT65 which requires three leads to take ZS readings (as far as I can tell...). BUT ... when I apply the probes (Brown on SW L (L1), Blue and Green at the Earth Terminal, it immediately trips the RCD before a reading can be taken. ------------------------------- Taking a ZS reading at a socket outlet is no problem as the kit has a bespoke lead with a three pin plug for this purpose. Is there anything I can do to get around this? --------- Thanks KK
