Discuss Kitchen extractor fan in the UK Electrical Forum area at ElectriciansForums.net
as pets says. use a SFCU instead of a JB. 3A or 5A fuse, depending on MI.
Hi I need to fit a humidistat extractor fan in the back kitchen, can I wire this into a junction box that runs from the main ring without an isolator?
Thanks I’m confused what would feed the fused unit, I am fitting a junction box to the ring main anyhow as I need to fit another socket in the back kitchen so would it be safe to run the SFCU from the new socket even though this runs from a junction box?
spur off the existing socket (or from the cable with a JB) on the ring to the new socket. then from the new socket fit SFCU for fan.
Reply to Kitchen extractor fan in the UK Electrical Forum area at ElectriciansForums.net
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Hi , I’m going install a commercial 450mm extractor fan , what size and type of cable should i use ?
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
