Discuss Kitchen Halogen lights to LED in the UK Electrical Forum area at ElectriciansForums.net
Jax
Hi, I currently have 13 (yes 13!) kitchen halogen downlights that I want to convert to LED's. They are the 12v halogen pin type connected to AC 240V transformer (60VA). Is it possible to convert these to to something like Philips 8W MR16 LED? Im not sure if the transformer I currently have is compatible?
Thank you in advance.
Thanks everyone. We did change the halogen lights in the bathroom to GU10s via electrician. Cost a fortune and that was for 6, I can only imagine how much 13 is going to cost. Was hoping for an easier/ cheaper option.
i'd price 13 @£80 + cost of whatever fittings you want. that's not a fortune.
So you are suggesting your labour charge would be £80
I'm guessing the OP is only thinking about the cost of the LED lamps -and not allowing for the other parts required which do add up.
yep. £80 labour, half a day at most. used to be a lot faster but slowed down a bit now. 71 year old legs and back getting the better of me.
Reply to Kitchen Halogen lights to LED in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Hi. I’ve got two pendant lights that currently run halogen lamps. One of the converters is broken so I’m planning to change both for LED lamps...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
This is the second set which won't work to replace the current spots here in my kitchen. All they do is flash once quickly. I'm replacing...
Hi all, I am trying to replace my halogen wall uplights (230W, 240V, R7S, 114mm) with LED but so far no luck. I've tried both of the below LEDs...
