Discuss Kitchen rewiring in the Canada area at ElectriciansForums.net
sjmgbr
Can anyone help me - I have just had a qualified elctrician rewire a room that is to become my new kitchen. The house is a bungalow with solid floors and for all the new plugs he has only run the wire down the wall from the attic and run all the wires alond the floors and has told me the will go under all of my new units. Is this legal? Am just a bit concerned as I understood all cables / wiring had to come vertically down the wall to the sockets?
HELP!
This is actually common practice. I rewire kitchens for councils and this is the way it gets done. As long as the vertical drops to sockets are chased and sheathed then that's fine. As for the draping cables behind work units - happens every day of the week on council contracts. I prefer to put mine in a horizontal run of plastic trunking so there is some mechanical protection but you could argue that if the cables are hidden by kitchen base units then they are 'safe'. There is good practice and quick practice. He has wired your kitchen this way for speed. Personally, if you had paid me, I would have chased EVERYTHING.
:eek::eek::eek::eek:
sorry cirrus dont agree:eek::eek::eek:
we do rewires for the council and i do the kitchens and mains........... anyway we always run our cables from above and down to sockets and spurs and then outlets. i go from one socket to anther from the side as it says you can in the regs but if its a long stretch then i go back up then across and down to the next socket. it would never enter my mind to run cables behind the units. all our cables go in pvc tubing.
I've certainly seen it done time and again. I wouldn't like to do it myself but as cirrus implies - it comes down to time and what the client is willing to pay!
We may not agree with it but it is standard practice and I have seen it done by several companies in the last 3 years.. I get to single handedly 1st and 2nd fix a large kitchen with 4 twin sockets, 4 /5 s/f/spurs, a fan, new ring main, new cooker circuit, test and also core a fan hole and install bathroom fan in one working day (including chasing). You have to do it in one day to make what the council pay you worth having!
Reply to Kitchen rewiring in the Canada area at ElectriciansForums.net
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Currently planning a new rewire for my kitchen and want to get things right first time when it comes to appliances consumptions and circuits...
Hi all, I posted here some time ago asking for validation of a quote I received for a rewire. (10k assumed 60 points) And got some good advice so...
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
