Discuss Kitchen spot transformers in the attic!!!!!! in the Australia area at ElectriciansForums.net
seb77
lads,
While i was working at a customers house the other day he asked me to look at 3 of his kitchen spots (12volt) that were not working. Anyway a VERY long story short i found the transformers.........in the ATTIC. A big bank of 60va trannys that do the bathroom as well. Now that means 12volts are running a fair way. quickly advised him to try and change them into mains spots or re-wire them. they are wired in 1.0mm t&e and must run all told bout 5 or 6 meters min. Never seen anything like it. just how bad is that???
I am not surprised they are not working, unless they are old 'non-electronic' transformers, the volt drop on those usually means that after 1.5-2m they have a very poor light output if anything. It is also bad practice not to site them locally, but it is likely to have been a 'DIY' job, seen plenty of them, hence you are there!
Reply to Kitchen spot transformers in the attic!!!!!! in the Australia area at ElectriciansForums.net
I have 9 spot lights in kitchen gu10 running 240v and 4 have stopped working. I have gone in the loft and they seem to be in two loops one with 5...
Hi Guys and Girls, First off: I am very new to electrical stuff. Right now I'm running my first ever project containing electrical components. So...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
