Discuss Klick roses on conduit end boxes in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Supporter
Just had a question put to me, cabling T&E On cable tray,lights are connected by klicks.
The klicks are mounted onto the tray, cables are looped into 25mm end box,plastic,
normal 3 x t&e cables,cable tied into position,does this contravene any reg, like the IP2X ingress protection.
Finger could enter the box,but not actually in contact with live connections.
You'd have to be a spider to get in 25's with 3 T+E's. 20's would probably be better, though.
Just don't do this with 'em.
You're more likely to suffer other injuries getting up to the tray than a shock from straying fingers.
Ripping you head open on overly long and or badly cut Threaded rod ends springs to mind.
I'd say it would only contravene the IP regulations if finger access could reach basic insulation. I assume these are already in place, but I suppose if that method of installation was being used a few inches of plastic conduit in the box spout would remove any prospect of access.
pretty shocking,especially when using conduit,could of been a nice job that?
Believe me it was totally S***, all through. I don't think I have ever seen a worse one. The photos aren't very clear but look closely at this one.....the joist and a downlight.
When I worked for a company in Manchester about 10 years ago I put hundreds and hundreds of 25mm end boxes with Kliks up with 2x 3c entering.
Nearly broke my nose or lost my eye more than once stripping LSF in winter on sites.
I knew an old boy who lost an eye doing this...
it was horrific
Reply to Klick roses on conduit end boxes in the UK Electrical Forum area at ElectriciansForums.net
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
I have a TPN board that will feed 8-10 sub boards. The loads on each board are negligible 5-10 amps peak but mostly 1-2 amps. The distribution...
I'm about to replace the cable from a starter to an existing 2hp 3-phase 3-wire motor adjacent. The motor is rigidly bolted to a bed and has a...
