Hi all I/m new to here and this is the first major installation of 3 phase and looking for advice
The unit has a incoming supply off 3 phase four wires with 2x 80amp and 1 x 100amp 1361 type 2 fuses. and used to be a truck haulage company
I am in the process of installing three, 3 phase ovens for the company which are all 14.5 kw each on a 3 phase supply.
With the other circuits the total we would be pulling would be around 82.2 kw total on balanced 3 phase.
At present we are running all but the three, 3phase ovens which are ready to be installed once confirmed.
The circuits are the following
3 x 3 phase 14.5kw ovens (to be added)
2 x 1 phase 6.5kw ovens
1 x 1 phase 9.5 kw dishwasher
1 x 3 phase 1.5kw mixer
2 x 1 phase 20amp radial circuit
1 x 1 phase 6 amp lighting circuit
1 x 1 phase CU unit of 50amp
The unit is for production of cakes therefore the ovens, dishwasher will be on most of the day.
We would be looking at adding one more oven of the same 14.5kw at a later stage.
Would the supply coming into the build need upgrading, if so which dept of the DNO would I need to contact.
