Discuss KVA to amps help in the UK Electrical Forum area at ElectriciansForums.net
Quick ball park sum for it is:-
3PH is Amps = Kva / 0.73
3PH Kva = Amps x 0.73
1PH Phase use 0.25 instead.
Since when did a DNO transformer work at 433v?
For the last 80+ years.
Measure the voltage at your house. I’ll put money on it not being 230V but nearer 250V.
I assume you’ve not been an electrician for long.
Haha always has to have a dig don't you? What relevance is that. For your info I was a electrician for over 8 years before moving onto bigger and better things.
Reply to KVA to amps help in the UK Electrical Forum area at ElectriciansForums.net
