Discuss L.E.D Floodlight Wiring Advice Needed in the UK Electrical Forum area at ElectriciansForums.net
Rob12
Hi guys, I have an LED flood light here that I'm trying to wire up but I'm unsure of how to actually connect it to the mains 240v UK.
Which terminals should I use inside ? Have attached a photo below.
There seems to be quite a few jumper wires on the thing and it has me confused !
Hi Ipf, I don't understand the label in relation to the terminal block....
There are short jumper wires on the label side, should those be removed for wiring or ?
Except that the label has been put on about one terminal to the right of where it should be!
There is a jumper between line and switched line that would be removed if it were to be switch controlled.
Switched live to switched live terminal, neutral to neurtal terminal and earth to earth terminal. It all looks pretty well labelled to me. If you don't have a permanent live don' remove the link.
This is a floodlight with emergency back up but presumably there is no battery pack supplied?
The wiring depends on how you are going to use it.
Post #10 is one way this may be another
but I do not know how the EM side of the light is operated.
Superb diagram buddy, thanks very much ! Will wire it tomorrow.
It's to mount above the garage doors and operate by an on/off switch when needed.
There is no battery pack inside - however there are 2 wires in the rear case for connecting a battery.
Thanks again for the great diagram fella
on the longer terminal block. L -1, S/L -4, N -5. (if you need the perm L to keep the battery back-up charged, otherwise don't use perm L.).
The obvious was correctly followed, don't open the box to read the instructions, post a thread up on here so us sad gits with no life can have something to do.
keeps you out of the pub. stop whinging. :)
Reply to L.E.D Floodlight Wiring Advice Needed in the UK Electrical Forum area at ElectriciansForums.net
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
I have a sawbench motor that needs an on/emergency off switch fitted, have the hylec on/off switch and a contractor 240V coil with NC contacts...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
