Discuss Labc minnor works in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
carl sparks
hi guys do u have to pay labc for minnor works ie new out side light as im useing this as one of my minnor job for niccy to see i have already done ccu with them as my major job just dont want to ring and fell a pillak
it depends where you are taking the feed from for the light,if running straight from db then its a new circuit and therefore is notifiable.
yes,however if he was taking his feed from kitchen light it is extending a circuit inside a special location and would be notifiable.thats the way i read it.
please excuse spelling mistakes, just back from pub. If the fittting is on the outside wall of the property it is outside the equipotential zone, sso i've been led to believe, therefore it must disconect within 0.4 secs easiest is IMHO take feed off an existing decent ring downrate spur to 3 A. covered
yes you could,but he has just done a board change in the property (i assume to 17th regs )so the light circuit will be rcd protected anyway so it makes no difference how he does it.
Reply to Labc minnor works in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello. I have a quick question for registered sparks on here. Can/ will / do you certify notifiable work done by others? I guess I’d have to...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
