Discuss Lamp holder getting hot in the Lighting Forum area at ElectriciansForums.net
Beeg
Evening all,
I changed the lamp in my dining room (ceiling light) for an LED one this evening.
When I took the old bayonet out, I noticed the plastic around the outside of the lamp holder was very hot. Could this just be due to the fact it was an old incandescent lamp therefore giving off a lot of heat? Is it normal or could it be a loose connection?
The flex between the lamp holder and the ceiling rose was cool.
Thanks in afvance
Beeg
Sorry should have said the bulb that was in it was 60W and the max wattage of the lampholder is 150W
stick a led one in and you should not smell ,if you l use a 60 watt and heat is generated form the bulb and will give off sometimes a smell when the bottom holder is not fitted for the lamp shade.
Thanks for everyone’s replies...I’m probably just being overly paranoid as normal! I’ll see how it goes with an LED / lower wattage lamp.
On a side note, just wanted to say how nice it is to have a forum that’s so welcoming and willing to give helpful and practical advice to people who aren’t qualified electricians.
Cheers guys/gals :sunglasses:
I wouldn't worry...if you have an incandescent lamp in a pendant, the pendant will get hot, and eventually you will have trouble unscrewing the shade as the retaining ring dries out and almost fuses to the thread...
As most on here will already know, there are 3 things that smell like fish...
and one of them's fish!
Reply to Lamp holder getting hot in the Lighting Forum area at ElectriciansForums.net
My Tesla UMC plug gets extremely hot and then defaults to the max output of 5amps after about 20 mins. However, I tried my brothers Tesla UMC and...
Hello, I have a very heavy frosted glass ceiling lamp and I have noticed that the top conical plastic part looks as if it got disconnected from...
My parents have a small well house covering a tank and well pump. The house and well house were built in the 1960s and the pump/control panel is...
  • Locked
5K
Moved into a refurbed flat a couple of years ago and there were a few suspect things about the electrical work which I’ve not got round to...
