RedJeep2020
- Reaction score
- 0
I'm refinishing all my pedistal lamps. This requires removing them from their concrete block posts and disconnecting the wires.
I've done 4 so far without any issues.
I always take a photo before removing the wire nuts.
Yesterday, after reconnecting the wire nuts on my 5th lamp, I flipped the breaker back on and the light bulb was ON. These lamps are all on a switch, that requires the switch to be ON before the light bulbs get juice.
I turned the breaker off and removed & replaced each wire nut. When I flipped the breaker back ON, the light bulb did not come on. I turned the switch ON & the light bulb DID come on. Curiously, now... none of the outlets work that are installed on the block posts. Prior to disturbing these wires that are beneath this lamp... all outlets did work. This lamp post has a fourth set of wires (BLACK) that the other lamps did not have. I've looked around for a GFI but don't see one. Any suggestions? I was planning to remove the lamp and inspect the additional set of 3 black wires that are wired together. This set of 3 wires is shown in the photo on the far right, (RED wire nut).
