Discuss Landlord Inspection?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Joe S
One of my customers rang me and asked if I could have a look and certify one of his properties. Is this a small PIR or a visual inspection? Can I do it being an NIC EIC Domstic installer and what certificate do I use?
Cheers
Thats a PIR you cannot do it as NICEIC unless you have been assessed by them as competent.
Chris
I am registered with the NIC and have a number. I am only domestic installer at the moment. I also have done my 2391. Just not sure whether or not I can do a PIR on the D.I Certificates I have.
Hi Joe depends what grade you are with the NICEIC you have Domestic Installer, Domestic Installer Test and Inspect and Domestic Installer & PAT Testing if they have assessed you on test and inspect then you can do it on their PIR forms. If you havent you can still do it but on generic forms not NICEIC forms
Hope that helps
Chris
Hope that helps
Chris
I guess I'm Domestic only then as I never got told what the title was. How do I go about upgrading to the PAT & Inspect and Test status? I am going do a PAT course in the next few weeks and am due my 2nd annual NIC assesment in May.
just buy some periodic certs from your local supplier you only need to be competent to do it joe , but it helps if you really know what your doing, you have your 2391 so get some money made mate.
If thats what it takes then I'll re-read my notes and stuff and go for it as I know whats involved. Whats the going rate for a periodic these days??
Best to contact the NICEIC it will be the same sort of assessment just doing it for PIRs and samples of PAT Testing and of course more money (so whats new). Check and make sure as you are domestic installer status the NICEIC may only assess and allow you to do PIRs on domestic only which is a bit of a waster when you have the 2391
Chris
Reply to Landlord Inspection?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'm a property owner who is needing to get an old electrical installation NICEIC certified. One of the buildings is a small office block with 6...
4K
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
NAPIT Certification Scheme Third Party Certification
Is there anybody out there in NAPITs Third Party Certification Scheme who would be willing to certify a new consumer unit I am wanting to install...
The seller is saying they will not upgrade the electric and it is normal to have 100 amps. However the inspector is stating it may trip often and...
