• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
Discuss Landlord needing Electrician to do landlord EIC and EICR in GLASGOW in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
If you can supply me with price to do these for a 3 bedroom flat, southside of glasgow, please reply to this thread with a price and contact details. Thank you.
One millions pounds and a varnished stoat.
Hi Lou. I think you are slightly confused between an EIC and an EICR. An Electrical Installation Certificate (EIC) is a certificate provided for newly installed work, hence the name. An Electrical Installation Condition Report (EICR) is a report on an existing installation. It is an EICR you need to let the property out.
Having an EICR carried out on your property is a little bit like having an MOT test on your car in that there is no guarantee that it will pass!
Thank you for your reply, ok so i need a price from someone in the Glasgow area for an EICR for a new rented out flat, can anyone help?
Reply to Landlord needing Electrician to do landlord EIC and EICR in GLASGOW in the Electricians Jobs area at ElectriciansForums.net
Due to demand, we need a qualified electrician who would like to teach. Suitable for all ages with a passion and patience, to pass on knowledge to...
Hi, new member here! Thanks for any advice in advance. This week I got a new consumer unit installed. The electrician has just sent me through an...
Went to fix a simple issue for someone . Then realised they where tenants and asked if they had a copy of the EICR ....NOPE . Turns out no Gas...
Hi all Called to do an EICR on a property 4 studio flats / bedsits within a single house. The t&e sub main to each flat runs within the fabric of...
We are new landlords and have just got an EICR done. The building is only 5 years old so I am shocked that remedial work has been noted as...
11K
