Discuss Laptop charger in the DIY Electrical Advice area at ElectriciansForums.net
J
Jaym98
Hello,
I had an animal bite through the wiring of my laptop charger and being an apprentice Electrician, decided to connector block the live and neutral cables (blue and brown) I just wanted to know if this is safe and will be okay to use? I believe it had a 240v input and a 19v output.
Thanks for any replies.
Hi Jay - no - all cable joints to be contained in an enclosure and provided with strain relief. I would advise replacing the cable as its going to cop a lot of flexing and if it comes apart it would be very bad. Hopefully it's detachable from the charger. How is animal?
Hi dude,you can get power leads off ebay for a couple of quid,probably not worth the effort or risk.
Also,change that picture...it's rotting my teeth :)
I'd go with post #3.
or you could use solder and heatshrink.
You should see what we were using for one of our laptops a couple of weeks ago! Dog chewed it, and needed charge quickly to get some documents off of it, had to just wing it and twist the wires, stood there while it charged enough to use, then binned the charger and clouted the dog. ha
Reply to Laptop charger in the DIY Electrical Advice area at ElectriciansForums.net
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
Hi there, I was wondering if anyone could advise me on the WT Henley Series 8 house service cutout. I have one of these installed at my house and...
Hi all, just a quick one to ask about an issue I'm having with my EV charger. I'll give a little background first but ultimately I want to know if...
Hello I have an old timed extractor fan in the bathroom which has stopped working. It has 3 wires which are black, brown and grey. I believe that...
